FS- Orange Rocker 1x12 Combo.
jd0272jd0272 Frets: 3867
edited November 2016 in Amps £
No longer gigging and it's a bit OTT for just in the house! 30 watts, clean channel (clean has no EQ), dirty channel, perfect rock amp. Comes with Orange footswitch (not pictured). Brutally loud amp, well gigged, sounds immense. I went straight to amp with this, only adding boost for solo's, these are that good. Just rode the guitar volume to get what I wanted.
And, it's orange. What's not to like?
Based Gateshead/Newcastle, can collect if you wish, arrange your own courier (access to secure/staffed 24/7 address), or I can courier, although I'd rather you arrange your own etc just cause it's an amp.
For courier quotes it's 24.5kg and dimensions are 545x285x450mm.
£300 PPG+ delivery chaps.
http://i1221.photobucket.com/albums/dd462/jd0272/20160906_133116975_iOS_zpsgsf1gk2k.jpg
http://i1221.photobucket.com/albums/dd462/jd0272/20160906_133158756_iOS_zpsjv65ni66.jpg
http://i1221.photobucket.com/albums/dd462/jd0272/20160906_133130239_iOS_zpsr3u1jlue.jpg
http://i1221.photobucket.com/albums/dd462/jd0272/20160906_133137585_iOS_zpswtxeykab.jpg
http://i1221.photobucket.com/albums/dd462/jd0272/20160906_133220130_iOS_zpsra0o3izr.jpg
http://i1221.photobucket.com/albums/dd462/jd0272/20160906_133230792_iOS_zpsckyihbyo.jpg
http://i1221.photobucket.com/albums/dd462/jd0272/20160906_133213652_iOS_zpssyis5foz.jpg
  • pauladspaulads Frets: 495
    Great amp (I have one)
    I've heard this amp at one of the aforementioned gigs and it sounded fabulous.
    a bargain :)
  • jd0272jd0272 Frets: 3867
    Bump for this wee orange box of ferocity.
  • London to far from you,otherwise this amp will be mine.
  • rocker6rocker6 Frets: 16
    I thought i had asked you, i want to upsize and it sounds like you want to downsize? Swap for a marshall sl5?
    Thanks for the offer chap, but I just don't need an amp now as no longer gigging.
    No probs, cheers for the reply
    Idle nudge. It's still very orange.
    It has a foot switch bump. Although the foot switch is not orange. It's white. Has a foot decal on it, what's not to like?
    It becomes less orange if you shut yer eyes bump.
    Cmon! It's Saturday and there are tits and ass on Imgur in User Sub. :)
    Dimensions and weight added for courier quotes bump.
    Wee bump.
