SOLD - Raspberry Pi 2 Model B & Raspberry Pi (v1- original)
For sale is a Raspberry Pi 2 - Model B with an 8GB SanDisk MicroSD card, in original box.
Also for sale is a Raspberry Pi, the original v1, with 8GB SanDisk SD card, in box (not original).
I can install Kodi with add-ons on either if the buyer so wishes.
Pi 2 - £20.Pi - £15.£30 if someone wants the pair.
Cheers
I could put something like Kodi on it, with add-ons, and that would be you set for a while, but eventually you'll probably want to update openelec (Linux based OS for RPi) - this requires PC use, but it's very simple.
All that's required is the Pi, a MicroSD card, HDMI cable and power cable (5v). You'll need some way of controlling it too, I use a bluetooth remote, a cheap one from eBay, otherwise you can use keyboard and mouse, as long as they're USB.
It will come with an SD card, and I have a spare 5v power cable I can throw in. People normally put them in a case too, but this isn't required for it to work.
It uses standard mini USB connection, but it's important to have the right voltage, too little and it won't work, too much and it'll fry. the Pi 2 requires 5v, I have a 5v cable for it.
I can put Kodi on the Pi 2 using openelec. Would you like add-ons installed? I could put Ares wizard and Fusion wizards on and you can choose what add-ons to install from them? I'm just being careful because I don't know your stance on using illicit add-ons nor where it leaves me standing as a seller. But also, you need it set up enough to a point because you're not using a PC.
