We have an existing QSC poweramp that uses jack inputs. We're thinking of buying a behringer SR16 digital mixer but this has speaker outputs on XLR. I am assuming that I can use a cable something like this:
https://www.thomann.de/gb/cordial_cfm_3_mv_klinkexlr_kabel.htm?ref=search_rslt_XLR+to+jack_199094_11Do I need balanced or unbalanced in this situation?
Similar question but to run IEMs we're going to intially go with wired from the aux sends into a headphone amp for each person. Again the output is a XLR but the input to the headphone is a jack. Will the same kind of cable do?
We're only going to have 4 aux sends for 4 members so these will obvs be mono mixes but I do want the mono mix coming out of both earphones for the IEM.
ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
Secondly the model of the QSC power amp will be reguired to determine if it has balanced or unbalanced input jacks. QSC is generally high quality so I would expect them to be balanced anyway, I am surprised that a QSC amp only had jack inputs unles it is very old or low powered.
Again without knowing the make/model of the headphone amp it's hard to give pertinant advice on it's suitability, some headphone amps might use a TRS jack as a stereo unbalanced input rather than a balanced mono feed.
Balanced becomes more important over distances and in 'noisy' environments, inside a small rack you will likely get away with unbalanced but if the option is balanced go with it.
To connect a single XRL output to headphones and get a mono signal in both ears you need to
Get an XRL lead and short pin 3 to pin 1 ............... now you have an unbalanced signal between pins 1 and 2 ..... Then
Connect pin 1 of your XRL to the sleave earth of the jack that's going to feed the headphone amp and connect pin 2 to both tip and ring of the jack that feeds the headphone amp ......... that will send the same unbalanced aux send from the desk to both ears
My other little company Dr Watson makes all kinds of clever cables for stuff like this, pre made cable is £15
@Danny1969
You got a website for that?
You can either get short (10cm) adaptor cables made up or a solid one like this: https://www.thomann.de/gb/thomann_sk083_adapter.htm
The cable I described earlier use's a standard mic cable with the adjustment one end. If you need to make it longer you just stitch on another normal mic lead ... or 2 or 3 or send it down a stage snake etc ........ that's the beauty of it
@PolarityMan I don't have a website for cable building, I just tend to build what people ask for, generally PA based rather than guitar. I'm happy to do try before you buy though if you want something
(I appreciate that everyone likes to do it differently and @Danny1969 you've got a ridiculous amount more experience than I have in these things)
http://medias.audiofanzine.com/images/normal/qsc-usa-850-954591.jpg
It seems pretty heavy to support only via the front panel screw fittings, even if i put it on the bottom I dont think the bototm of the amp will be in contact with the bottom of a rack case.
Im pretty sure for everything else just screwing in via the fron rack mounts is fine but do I need to get some kind of rails or supports for the amp?
EDIT:
More stupid questions, am I right in thinking that the poweramp is 2U and do you need to leave space above the power amp for heat dissipation?
That amp vents through like most but I still like to leave at least one U between the top of an amp and something else above it. How hot the amp gets depends on how loud your driving it and the impedence it's driving into ..... to be honest once you put more than one power amp in a rack it gets pretty heavy .... so I wouldn't put much else in the rack with it
I'll prob get back to you on Monday about those cables btw.
