Stupid Builders.
Just found out that our House Built in 2010 has a problem with the drains in the kitchen sink because the stupid builders didn't connect the drains properly.
The pipe literally goes straight into the ground and so the smallest amount of solid waste causes a blockage.
It's going to cost £4000 to get it fixed but thankfully the builders are paying for it.
  • paulnb57paulnb57 Frets: 3074
    I never cease to be amazed at the poor workmanship and quality control surrounding houses, which are our biggest ever financial investment, the utter shite that Barrats and similar throw together is apalling....
  • hotpothotpot Frets: 846
    My daughter lives on a new build '2012' housing estate & almost everyone has experienced drainage/sewer problems from day one.
  • CHRISB50CHRISB50 Frets: 4327
    You should get a guarantee of some sort with a new build covering you for quite a while.
    I think ours was built in 95 ish and we took over the guarantee from the previous owners when we bought it. It lasted for about 15 or 20 years if I remember correctly.
  • MtBMtB Frets: 922
    edited October 2016
    It's because there is no quality control / inspection of the build (other than the foundations). The builder is able to build and sell what they want, and it's for the punter to know the building regs inside out if they want to buy a decent spec house that's been properly finished.
    If I were buying new I think I'd hire a building quantity surveyor (or a renowned quality builder) to inspect the build for me as it progresses.
  • NeilNeil Frets: 3641
    I did once own a brand new flat complete with cardboard walls etc. Never again.
    I can't believe how thin modern roof trusses are. :o
    These places are never going to last as long as their forebears.
  • boogiemanboogieman Frets: 12434
    The standard NHBC guarantee is 10 years. I'm amazed that the OP's issue of drains wasn't picked up by the local inspectors though. They're normally around all the time, like flies round shit. When we had a small extension done last year we must have had 6 or 7 visits over the space of a few weeks to inspect footings, insulation, roof trusses and wall plate, steelwork etc. Done for all the right reasons, obviously, to stop cowboys taking shortcuts.
  • I thought the point of building inspectors was to prevent cock-ups like this?
    That planning system is odd. I'm trying to extend my house and the planners are even dictating what kind of garage door I use, yet builders are getting away with screwing up the basics like this. That's a flawed system.
    We had loads of building inspectors when it was first built and the NHBC signed everything off and have guaranteed it for 10 years.  Unfortunately they are useless and they said we first have to contact the builders, if they don't respond for at least a month then they get involved.
