e.g. https://www.jacksonsart.com/w-n-1-litre-sansodor
https://en.wikipedia.org/wiki/White_spirit
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Brake cleaner can be mostly naphtha, although it's worth checking the MSDS to see what's in it. Pagid is 95%...
http://www.hella-pagid.com/hellapagid/assets/media/HPBS_SafetyDataSheet_BrakeCleaner_ENG.pdf
Stuff number 921-024-6 (page 2 for C6/C7)...
http://www.reachcentrum.eu/Consortia Documents/P-I163/Other/20110401160024-HSPA_CAS_April__2011.pdf
A quid for 100ml of lighter fluid at Asda, or about 15 quid for 5 litres of brake cleaner. The lighter fluid tins are very handy for dispensing small amounts. I got a 5L can ages ago to use as fuel in my Primus multi-fuel stove (works very well indeed).
For degreasing or cleaning in general, different substances work better for particular things. The blue stuff I use on my metal machining work (for marking out, called layout blue) is hard to shift with naphtha, but isopropyl alcohol takes it off instantly. Neither is much good for getting some kinds of sticky label residue off, but an artists oil paint diluent I use called Zest It works a charm.
Nomad
you can also get "petroleum ether" from bulk chemical suppliers that is also naphtha.
note that naphtha isn't a single thing, it is a range of compounds with similar characteristics, but they are not identical. That is where a lot of the confusion arises. As far as I know they all work as a not too aggressive solvent, but as ever test them somewhere inconspicuous on the finish first!
Is it safe to use on fretboards? I can't get naptha here and no one will post it to me.
Aye.
