What exactly did you use?
Probably fine to desolder it all, clean the jacks and redo it with electronics solder.
Also if you can find out exactly what flux he gave you - it might not be a problem at all. Exact brand and type.
Yes, modern, solder is flux cored and no extra is needed for small jobs like jacks.
However if you are attempting a bigger job, soldering to chassis e.g. a smear of good quality rosin flux helps things flow enormously, especially with Pbfree solder. But in any case, preparation is the key to easy soldering. Clean the wires and the plug contacts with an abrasive then wipe with ISOPROPA. Makes a huge difference. N.B. some plugs etc have a very shiny plated surface that resists solder (don't know WTF they do it!) A fine file or Stanley blade can be used to cut through the plating.
Dave.
EDIT: I think I'm being my usual paranoid self again. It'll be fine LOL
