I finally got to the place where I was happy with my board and was looking forward to a good stint of no tinkering/GAS/messing around.
It didn’t last long. A friend of mine who plays a similar amp (Two-Rock Coral) gets a great sound from a way huge pork loin – so thought I’d give one a go (hoping I wouldn’t like it). I also had one last loop to fill on the G2 ! The problem is – the pork loin sounds great too. Slightly fatter sound than my other OD sounds (Amp ch2 and KOT).
So, I now use a whole bunch of overdrive sounds for different things - i.e. amp OD for sitting in mix (and works well with bit of comp), KOT that stacks well quite nicely and then Pork Loin for a bit more chunkier tones (but doesn’t get on so well with comp, I find). TS DX does the higher gain stuff and has been no.1 choice for nearly 10 years !
Do I keep the setup as it is and try to use all these slight nuances for what are all light overdrive sounds - or try to simplify it ? I had a gig not so long ago when the pedal board went down – and I just used the KOT and the volume control – it was quite liberating…but don’t think I could be one of those players.
I know these aren't real problems – but I spend way too much time thinking about it !
9 times out of 10 the audience aren't going to know the difference, but YOU will, and that's what matter's.
I always find the guitar to play better with the RAT on and i push that through a tonebender so the RAT can hardly be noticed
Just think of all the far more fun and dramatically sound changing pedals you could use!
That said the best is what ever works for you.
R.
Eqd Speaker Cranker clone
If I need a mid gain thing then I use the guitar volume to clean up.
Fewer pedals means you spend more time concentrating on playing and less on tap dancing.
YMMV.
I find it works fine with a compressor running into it, not after.
I'm going to simply this weekend as an experiment. It will be the klon-type for low gain, a quality TS style for mid-gain and then a quality Rat-style for higher gain. Three sounds, no stacking, all switched with a flip-flop switcher so that I can get from to the other with one button push.
Lets see how it goes!
