The G12M-70 is almost the exact opposite, very middy and a bit honky. Not usually a very highly regarded speaker, but it can sound good in combination with something more scooped. It's also good with solid-state amps because it has no real top or bottom, so helps prevent boom and buzz.
The 4-ohm impedance is a bit restrictive - obviously you could put two of them in series to make an 8-ohm cab, but they would also be suitable for many solid-state 1x12" combos which are often tricky to find good 4-ohm speakers for.
I had one of those cabs which I put a pair of Powercel 100s in - great cab.
