Yet another "which audio interface" thread
For various reasons I'm looking for a new audio interface, so welcome any thoughts and suggestions. The requirements I have are:
4 in / 4 out
Inputs with phantom power and combination mic/jack sockets that can also take instrument level signals
As many inputs and outputs as possible accessible from the front
Budget around 250
I'd really like it to be bus-powered, but from looking at what's available I suspect that this may not be possible - maybe because the USB bus does not supply enough power to send phantom power to the mic inputs as well as power the device itself...
What I have found so far:
Focusrite Scarlet 18i8 - a bit over budget
Presonus Audiobox 44VSL - almost looks great, but WHY DID THEY PUT THE HEADPHONE OUTPUT ON the BACK?? FFS...
M-Audio M-Track Quad - could be OK, but I'm a little suspicious of the quality of M-Audio's mic preamps
Akai EiE Pro - is this the same as the M-Audio repackaged in a different box?
Anything else?
    I have a Steinberg UR44 - it's Yamaha technology and I find it great - super stable, quiet and low latency. Comes with some great Yamaha plugins.
    http://www.steinberg.net/en/products/audio_interfaces/ur_series/models/ur44.html
  • JeremiahJeremiah Frets: 631
    Thanks, that looks pretty good.
    I also noticed the Tascam US 4x4
  • Ben8010Ben8010 Frets: 150
    edited October 2016
    The Focusrite Scarlett range is really nice and you get some very nice plug-ins from softube & focusrite themselves with them. Really good value all things considered so that's my recommendation.
  • Another shout for the Tascam 4x4.
  • blobbblobb Frets: 3002
    NI KA6
    Feelin' Reelin' & Squeelin'
    blobb said:
    NI KA6
    Hmm, I was looking at this, but it only has 2 mic premps when I was really looking for 4. Not that I really need four, but I'd like to be able to experiment with multi-micing from different positions etc. On the other hand, it the bundled software looks quite interesting
    2 mic / line combi + 2 line level + 2 digital in's (so they label it as '6 in / 4 out')  so yes, only 2 mic inputs. You're going some if you need 4 mic in's. I always found 2 mic positions to be sufficient but now I tend to record a mic plus direct out with a cab sim and they sound identical. So much so that I may be done with mic's on amps.
    Best bits are:
    - driver stability
    - latency
    - pre amp quality
    - build quality
    - software
    bad bits are:
    - can only use the direct monitor on input 1&2 - which are the combi's (although you can send it to headphone and out 1/2 or out 2/3) you can still monitor all in's via DAW.
    - only 1 headphone out.
    Pro's outweigh the con's by miles.
  • I have the Scarlett solo, but would definitely like the 18i8. Think you could get it on budget.
