I suspected that removing all of the strings could induce unwanted floppiness.
It's no real difference to a 6 string (Aside from the obvious) but more work and it's easier to make sure you have hold of the right string before putting it on.
Stretching in is no different except for that high G,....................I usually just go as far as i dare and then resign myself to it going out of tune for a day or so while i play it.
I usually play pinball wizard on one afterwards to give it all a good rattle and then retune.
I miss my 12 string now.
Why did i look at this?
Best of luck.
I've never understood the whole '12-strings are hard to tune and change strings on' thing - why are they any different from a 6? If you can string and tune a 6-string so it stays in tune, you can do the same with a 12. If you can't with a 12, you're going to have trouble with a 6…
Exception: Rickenbackers, purely because of the half-slotted headstock design. Even those aren't a problem if you do them in the right order - all three post strings off first on one side, then the slot strings off starting at the far end. Then fit the new ones in the reverse order starting at the nut end, then do the same again for the other side.
With a 10-47 12 string set, off the top of my head, the octave G is 0.008 and tuning that 3 steps above the high E string can be pretty daunting/it's a lot of tension for one string. If you are like myself and use alternate tunings (e.g. Open C), with off the shelf string sets, I find some of the octave strings often lack tension and consequently can be tricky to keep in tune.
Tuning/restringing a 12 string isn't as complex as many make it out to be, it does take a few times to get used to.
i have never had that level of stability on 12 before
Instagram
I'm a big believer of multi piece laminate necks/CF rods; the latter being one of my favourite 'modern' innovations (multi piece necks aren't modern, but I think they are great)
