The Dr Scientist Cleanness my favourite pedal, and the sodding footswitch has started playing up. Yesterday I couldn't engage the pedal at all, and I'm worried it's going to give up the ghost. It's been working sporadically recently, but get the feeling that it's only a matter of time and I don't think I can do without one: having a Space at the end of my chain, I need a good buffer/boost at 18V for the headroom, it really helps me retain my tone. Without the Cleanness, even with the Space not being engaged I do experience some tone loss.
Is there an alternative to The Cleanness, if worst comes to worst? Should I try and find a used Elements instead?
And if the problem isn't just the switch? I did say "if worst comes to worst" in the OP.
Empress buffer or some other buffer.
Or get your pedal a) fixed by @juansolo if he can help (I imagine it's a cheap 3dpt thing or whatever they are called) have it modded so its always on (I seem to recall you do have it always on?)
C) but a Cornish or a klon :-p
I'd probably just change the switch.
All of this will happen anyway.
And I thought I was pessimistic!
It's not always possible, but sometimes you can transplant a more reliable switching scheme in - it depends on the circuit and how much space is in the box.
