Strymon flint
TeetonetalTeetonetal Frets: 7815
What a pedal. Seriously how have I not had this before? Just beautiful.
  • I still need to get one in my life......
  • Just wondering, before or after delay....
    I'm thinking after as that's where it would be if built into an amp.
  • DesVegasDesVegas Frets: 4609
    After
  • bbill335bbill335 Frets: 1389
    If you're using it for spring reverb, I'd say before delay. If it replicates the mechanical drip as well as the strymon demos for the flint, I'd want that drip to get repeated. I don't think you get quite the same effect going the other way.
    If you treat it like a vintage outboard trem/spring verb unit, it would be going direct into the amp's input. If you put it in an effects loop, it's between the pre and power amps like in a blackface Fender twin or similar.
    If you use those other reverb modes, I can't help you because I only like drippy springs  B)
