Some people will find a setting that works on both channels, others won't. Just depends on taste and usage, so the amp will be right for some and wrong for others.
If the amp's only being used for one sound at a time it also doesn't matter - say it lives in a recording studio, if you want to change channel you can just go and tweak the EQ.
In a live environment, an amp either works for you or it doesn't.
Bandcamp
Spotify, Apple et al
The only times shared EQ has been a problem have been on three-channel amps -
1 - Soldano Decatone. Perfectly possible to get any two channels right, the third was just impossible.
2 - Randall NB King 30W - lead and rhythm channels share EQ, and both were crap on almost any setting Just a poorly-designed amp all round, really.
To make it easier, you could get one of those loopers/switchers which enables you to switch channel and engage a pedal in one stomp?
Sharing an EQ section between clean and filth however would have been less successful as I always seem to end up with the mid controls in particularly set very differently...
I tend to find more mids preferred with gain and a flatter eq on clean.
If there's a large difference in gain then either the clean will sound dull or the drive harsh in my experience.
There are exceptions to this, if the designer has thought about it and actually added extra fixed voicing tweaks between channels that aren't controlled by the EQ knobs.
My current amp (Mesa Lonestar Special) has two sets of eq and is better - but not perfect.
I think few amps are really successful at doing both things well.
Excuse the poor playing and bassy mix.
Mexican strat into a Laney Lionheart
Shared EQ for the clean and light overdrive, then a boost, a distortion, and a fuzz at the end.
No changes to EQ on the amp between sounds, no post-EQ, and the reverb is the amp reverb.
Have you have the 'pot swap' mod done? (Swapping the gain and master pots on the lead channel - no new parts needed.) It makes a surprisingly big difference - essentially it makes the two channels much more similar to each other, exactly as I would want.
I think a fair bit of it with shared-EQ amps is down to starting with the dirty channel rather than the clean too, since it's usually more 'touchy' - the Fender Hotrod is a good example of that for me. If you dial it in for the clean channel it can sound bad on the drive one - but if you do it the other way round and let the clean channel take care of itself, it's more successful. I am aware that I may be unusual in being able to get a sound I like out of the drive channel at all though .
I never use the second channel live for the same reason as the OP, but if it had the same voicing I would.
I love about five different settings on my Dirty Shirley so two identical channels would be ideal.
