How do you extend WiFi signal?
I've got a Virgin Superhub 2 and get great speed in the house (150mbps) but to get signal in the garage I need to use a TP Link extender, and even then I only get 10mbps.
Is there a solution to get the same 150mbps or close in the garage?
Its a separate building outside so the signal needs to go out the living room, down the hall, through the kitchen and then out the wall and in to the garage.
  • octatonicoctatonic Frets: 33846
    Ok, I've been in this situation.
    Is the TP link a power line adapter?
    If so then a different power line adapter might work better.
    But if the distance from the Superhub to the garage is too great then there will be a limit to how well it can work, in which case an ethernet cable run would be better and then use a wifi router connected to that in the garage.
    My workshop is connected to the house by a covered hallway.
    If I use a power line adapter in the workshop (which has a 100ft armoured cable to power the workshop) then I get 10mbit in the workshop.
    Moving the power line adapter to the hallway is a shorter cable run back to the RCD and I get 70mbit internet in the workshop, which is how I got around the problem.
  • quarkyquarky Frets: 2777
    edited November 2016
    I joined another wifi router via a Cat6 cable, and enabled a different network with a different SSID from that second one. Then when I am in another part of the house, the device can connect automatically to that one, because the signal is so much stronger, and get decent performance (like Octatonic's first suggestion).
  • DefaultMDefaultM Frets: 7373
    Pretty sure that this is the one that I've got https://www.amazon.co.uk/TP-LINK-TL-WA860RE-300Mbps-Extender-Passthrough/dp/B00M0KILOA/ref=sr_1_4?s=computers&ie=UTF8&qid=1480278852&sr=1-4&keywords=tp+link+range+extender
    I bought it on a bit of a whim and I don't think I got what I really wanted. I have the super hub in the living room, and then I've connected this in the kitchen. I imagined that when I went in to the garage I would search for wifi and I'd see one that said TP Link and then I'd connect to that, but I still connect to the original router.
    I assume what it's doing is the signal from the router hits it and then this just kicks it a bit further?
    I would try a different (and probably more expensive) device first.
    I use Devolo DLAN 1200+ devices.
    We have one base station and 5 extenders to give us wifi in every room in the house, the workshop and the garden.
    You might not need so many, maybe just a base station and an extender.
    You can't cheat science though, if the power cable run to the garage is too long then you can only use a socket with a shorter run, or switch to Cat 5 (I'd probably go with Cat 6 now though).
    I do it differently with the network- the Devolo boxes are all set to the same network name and password- I can seamlessly move from room to room and no loss of signal. It is pretty nifty.
  • SambostarSambostar Frets: 8745
    Cat 5e or 6 cable, a second router and some man graft.  Cable and a second TP link cheap router standing around at 10m beats the speed you can get from a BT homehub at 2m.  All you need is a pickaxe and a spade boy and run it out.  Magic doesn't exist.  It's a simple thing that of you can't fix yourself then you must ask yourself.
    Backdoor Children Of The Sock
  • fretmeisterfretmeister Frets: 24634
    Ive got these power line ones
    https://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
    They work well. Extend the signal via the wiring, and then are wireless. Both units can be plugged into as well for a wired connection.
  • I tried a power line adapter. My router is in the living room, my bedroom is upstairs and other side.
    It didn't work at all. It did work in the living room though. I think my house must have odd wiring?
  • capo4thcapo4th Frets: 4437
    I am looking into a similar problem and was gonna try the power lines today. If they don't work I will take them back and look at a cable solution.
  • Virgin Superhub has ethernet and Wifi and you can have it do both at the same time - a bit fiddly to set up as I recall.  Ethernet is far better than wifi.
    Picked these up today and they work a treat two minutes to set up £99.
    http://uk.tp-link.com/products/details/cat-18_TL-WPA8630P-KIT.html
    Didn't complete a speed test but seemed quick enough on Sky Fibre.
    Might add another upstairs for those sitting on the toilet fretboard moments....
