Usually into the front of the amp is fine. You only really have to use an FX loop if you are using delay or reverb and you don't want the trails to be distorted.
Eqd Speaker Cranker clone
Thanks chaps. I take that as a green light. I was thinking of buying a Blackstar ID Core-10 while they are on offer at £65 from Coda. Then I thought if I buy a pedal at the same time, it will push the price over their 'free-postage' threshold and I'll save £8.95 :-)
They sell the Boss RC-1 Looper at £75. Anyone see any problems there? i.e. a Boss RC-1 Looper into a Blackstar Core 10 amp just for the practice room?
Should work fine. Just note that you'll have your loop being influenced by the preamp eg if your amp is distorted, so will that be. If you had an amp with an effects loop, you could put it there, record a clean chord progression in the looper, then use distortion to jam over the top.
But yes, it'll work anyway.
The work around of course is to have a distortion pedal before the looper, so you can go Guitar - Distortion - looper -amp.
op needs to buy another pedal....
The one place you really can't put pedals is between the amplifier and the speaker. Yes, the connectors look the same, but the higher current going through that cable will be a thoroughly upsetting experience for your pedal, your amp, and potentially your wallet.
Oh dear! Just as I'm about to buy, I come across an ad for the Zoom G1on and G1Xon multi-effects pedals which at first sight look really good at a cheap price. After Interwebbing reviews, demos etc. they look to be amazing value for a beginner.
Any opinions, guys? Bear in mind this is for practice use only and I'm an electric beginner.
The looper will improve your playing most, in my humble opinion. The multi effects will introduce you to all the different sound options and you can Learn which sounds you like and dislike...
You pays your money !
Keep askimg questions here; theres some good people on here, and we'll always try to help out
For simple stuff - recording a few bars of rhythm guitar to play over etc. - the looper on the G1on should be more than adequate- you'd need to go for a dedicated, full-featured looper to get some of the crazier stuff- undo, multiple speeds, more footswitches to allow you to do more stuff "on-the-fly" etc, particularly if you wanted to perform looping-based music live, but for an introduction to looping and a first step in to that world the G1on would be fine.
The great advantage of a cheap multi-effect early in your guitar playing life is, like @Wazmeister says, that it'll give you a good idea of what a wide range of effect types sound like, whether you like those sounds and what you can do with them in your own playing. The Zoom units are very cool in that respect because they allow you to mess with the order of the effects in the chain instead of being forced to use them in the "correct" order, so you can get in to some really cool unorthodox sounds too.
...which leads me to the big disadvantage of a cheap multi-effect early in your guitar playing life. It's very easy to get lost in the world of making silly noises with your guitar instead of learning to play properly. Don't get me wrong- the electric guitar has been one of the pre-eminent silly noise making instruments of the last sixty years and should stay that way, and making electric guitars not sound like electric guitars is a time-honoured tradition that ought to continue, but a guitarist who can only make his guitar sound like an elephant having bum sex with a whale isn't going to be much use to most bands.
Likewise, it's easy to get absorbed in crafting perfect conventional tones- experimenting with all twenty-odd amp models on your multi-effect and twiddling EQ knobs to get it just so, then adding just the right amount of subtle delay or reverb or chorus or whatever, but a fantastic guitar sound is nothing if you can't play anything with it. Having all those sounds at your fingertips can be a distraction from the less immediately gratifying but more useful elements of practice.
how does it sound? Huge, wet, wrinkled and repulsive, yet strangely arousing.
Hmmmm.... all this talk has me excited - I'm ordering the Zoom pedal right now.
And a few picks with it; just because I can :-)
That's how I run mine - df2 - dd2 - ds2. That way my lead tone repeats don't get nasty, they just sit in the background but my rhythm repeats blend nicely.
