Stripping the finish off a neck
I've got an Aria Pro II that's been in bits for a few years that was originally finished in an awful clownburst.
I've stripped the body back to bare wood but was wondering if anyone had any recommendations for stripping the neck?
I don't really fancy sanding it as I may change the shape and it takes bloody ages.
Wood paint stripper work if I masked off the board?
For reference it started out like this
  • WezVWezV Frets: 16894
    paint stripper probably won't work on that.
    I tend to scrape most of the finish off the neck and finish up with sanding....  quicker than just sanding and no heat needed!
    cabinet scraper  or a razor blade used as a scraper will do it fairly quickly
    ooh that sounds really dangerous, I'd be worried about taking chunks out of the neck wood!
    nah - is dead easy and less likely to reshape the neck than sanding through a thick hard finish.  Just remember you are scraping the finish, not the wood at this stage.  Stop when you get down to the wood
  • will give it a go
  • SteveRobinsonSteveRobinson Frets: 7097
    The most dangerous bit is that shards of finish will fly off so wear some eye protection.
