First crack at mic-ing an amp...
AndyJPAndyJP Frets: 221
edited December 2016 in Studio & Recording
Hi all,
Recently had my first crack at recording using a mic-ed amp. Have always used modelling software in the past.
What are you thoughts on the guitar sound?
Using a single sm57 into a simple focusrite interface. Amp is a Victory V40. Zilla cab with a 1 x 12.
Cheers,
Andy
  • Sounds like a recorded guitar, Andy! Was it what YOU wanted to capture? If so, job done. It doesn't sound 'badly recorded'.
    I never get the recorded sounds I want out of modellers or sims, so credit to you for bothering to go the extra step.
  • CirrusCirrus Frets: 8495
    Sounds good to me!
  • AndyJPAndyJP Frets: 221
    Cheers!
    I wanted to simplify things and spend less time tweaking sounds at a computer.   So thought I'd give the mic a shot.
    I honestly think I got it done quicker with a mic.
    So, how'd you position it on the speaker and how did the recorded tone compare to the sound in the room?
  • relic245relic245 Frets: 963
    Sounds good to me. Out of interest, what kind of volume was the amp?
    I know that's subjective so I guess I'm asking was it, ok for in the house volume, ok occasionally in the house but would piss the neighbours off after a while volume, rehearsal volume or full chat?
    If that's first attempt though I'd like to hear more when you get the hang of it :)
    A single SM57 placed on bottom right of the cone, almost touching, and off axis.
    As for sound in the room, that's where I simplified things (cheated).  I recorded the guitar dry then added some reverb in the DAW via an aux track.  Figured could get whichever room sound I wanted this way.  Also added the same reverb to the snare.
    Cheers buddy, thanks for the compliment.
    It's a Victory V40 which I set to 7 watts.    As for volume it's not as loud as a rehearsal room volume but slightly louder than home practice.
    The thing that really helped me get a decent sound at a lower volume was a compressor. I used a Wampler Ego Mini set with a low blend and subtle compression settings to reduce the dynamic range a little.  This allows me to dig in without taking the roof off the house.
    Gonna get more recordings done for sure!
    Have re-recorded the bass and rhy guitars. A little tighter now.
    Will have another shot at the lead guitar over the weekend, it's a little safe.
