Do I need a non mid hump boost?
sgosdensgosden Frets: 1994
I'm currently using a victory kraken (channel 1), boosted with an eqd palisades for a lead tone, unaffected for ryhthm, and volume down for cleans.
I want something that'll boost the amps gain the same way the pali does, but without the mid boost, for more chunky tone when doing palm muted type parts.
I'm guessing I need something with more of a V shape eq curve.
Or maybe even an eq pedal in the fx loop?
Any other suggestions?
  • BintyTwanger77BintyTwanger77 Frets: 2236
    edited December 2016
    An EQ would work. I hear the Source Audio one is pretty good.
  • sgosdensgosden Frets: 1994
    midi too which would be helpful...
    Suprised you didn't say 'riverside' straight away :P
  • simonksimonk Frets: 1467
    What about a Suhr Koko Reloaded? Best of both worlds then.
  • monquixotemonquixote Frets: 17670
    I've been hugely impressed with the TC Spark.
    You can do flat, mid, or low end boosted, plus it has 2 band active EQ.
    Ha! I'm going to stop banging on about it now.
    I did consider the spark, but thought the fat boost aspect might just go a bit flubby in a gained up amp?
    I'm just jealous because I want one ;)
