Twin Reverb wiring idea...
TrudeTrude Frets: 916
I've recently borrowed back my old '65 TRRI from the mate I sold it to some years ago, because I've been hankering for that sound again.  Mucking about with speaker configs at the moment...
My idea is to wire each speaker to an individual jack (they're normally in parallel - 8ohm speakers, giving 4 ohm load overall).  I'm thinking I can keep it stock by plugging one speaker into the internal output, and the other into the extension output, assuming these two are wired in parallel.  Then when I fancy getting clever I can run a low-power head (something dirty like an 18w Marshall) into one of the speakers, and pull two of the 6L6s to keep the Twin matched to the 8ohm load of the other speaker.  This will give me a nice two-amp clean/dirty rig without needing two separate cabs.
Any reason why that shouldn't work?
Some of the gear, some idea
Trading feedback here
  • ICBMICBM Frets: 72819
    That will work fine. The speaker jacks are in parallel on the Twin - apart from late-70s 135W ones, which are in series.
    You probably don't even need to pull two valves really - it's unlikely you'll be cranking a Twin to the point the impedance mismatch will matter or the power would be a risk to the speaker.
  • TrudeTrude Frets: 916
    Even better - thanks!
