Woodworking machine tools and methods
Jimbro66Jimbro66 Frets: 2431
edited December 2016 in Making & Modding
My old Bosch plunge router needs replacing due to general wear and a creeping plunge mechanism. I use a router from time-to-time for things like pickup, control and trem cavities in guitars in addition to general joinery work. I was thinking in terms of maybe a fixed/plunge type that can be used either for cavity routing using templates or with a router table for other work.
Do any regular router users here have any suggestions or recommendations please? I'm thinking in terms of maybe £200 - £300ish budget but I'm flexible on that.
  • octatonicoctatonic Frets: 33836
    I have a Trend T11EK in the router table- it is very good for that job, I've never used it outside the table so I can't comment on how it does as a plunge.
    My main router is a Festool OF2200 but that is a bit spendy.
    Very, very nice though- wasted in a router table.
  • SporkySporky Frets: 28661
    I was thinking Trend at that sort of budget. Very decent.
  • Jimbro66Jimbro66 Frets: 2431
    Thanks for the suggestions @octatonic and @Sporky. I'll look up the Trend routers. Yes, I've heard of Festool but I think probably way beyond my needs and budget. Maybe one day ;)
  • DanielsguitarsDanielsguitars Frets: 3300
    edited December 2016 tFB Trader
    I'd go with the dewalt 625, its cheaper it's based on the trend and i even think its made in the same factory
    I do find these ones heavy for hand held routing, one of the reasons I went small pin router
    www.danielsguitars.co.uk
    (formerly customkits)
    Small pin router?
    The Trend has better above-table adjustment than the Dewalt.
    Small pin router?
    yeah the small overhead pin routers
    It does depend on what you want it for though and how often you use it
    You have the templates on the bottom that ride on a pin with the cutter above, much better to see where you're going
    Oh ok thanks
    Small pin router?
    Thanks, I'll have a look at those.
    They don't come up that often
    I wanted 240v not 3 phase
    They get too big for my needs
  • GSPBASSESGSPBASSES Frets: 2351
    I would definitely go for the trend T11EK, they are in my opinion the best industrial router you can buy. I might be a bit biased on this subject, as I own 4 them, that might sound a bit over the top, but when you do as much routing as I do, it is so much easier to have several router setup to do specific jobs, then to keep changing cutters and resetting the router up. I have two router setup for hand routing, one with a 6mm cutter, for routed truss rod channels, and one with a 9.5mm cutter use for pickup cavity routing that cannot be done under the pin router. I have one set up in my overhead pin router that doesn't nearly all my routing work. The fourth one I've only just purchased will be going in the overhead router. I do have a DeWalt equivalent to Trent, but to be honest with you, it's not very good. Although everyone says it's identical. It really does lack the power of the Trend, it is now only used fixed under a bench (acting as a router table) to rout binding channels in necks and head stock's.
    Very interesting @GSPBASSES.
    Did you build the overhead router yourself?
    Thank you so much for that post @GSPBASSES it is really very helpful. I have never used a pin router although I had seen them in use but not realised what they were. Thanks to you and to @customkits, plus a little research online, for educating me. Nice setup in the video. I can see how that is preferable to manoeuvring a heavy-ish hand-held - but no doubt after a lot of practice.
    Trend T11EK has the majority recommendation here, thanks all, so that's the way I'll go.
    I've noticed that the T11EK is supplied with a 1/2" collett and that a 1/4" collett is an optional extra. Any comments on what I should get? My old Bosch is 1/4" only.
    I have 2 small pin routers one is old with big motors and more industrial
    I have another and i can't remember who made it, it came with a big elu motor but what's good is you can take the motor off and mount another router on an adapter plate that comes with it, we use a trend tk11 on that
    Another thing is you can mount the router underneath and take the pin out
    It does take a bit of practice to get the hang of it
    Also I cut all my pickup cavities with the pin router, it's so I can angle cavities to go with neck angles, I like seeing where I'm cutting
    I use 1/2"   1/4" and 3/8in
    It depends on what your doing
    OK, thanks for your advice.
  • martinwmartinw Frets: 2149
    For occasional use, I would have thought the Trend T4 might be enough?
    I've had one for a few years now, and I would classify my usage of it as 'light trade'. It's had a lot of use and is still performing faultlessly.
    Trend have good parts back up (not that I've needed it), and I added a fine height adjuster to it.
    It's nice and light, so it's easy to handle, and its 850W is more than enough for what I do.
    Thanks for your input Martin. Was the fine height adjuster a Trend accessory or something you fabricated?
  • WezVWezV Frets: 16771
    At the lower, less industrial, end of the market I really like the Bosch palm router... GFK600 or something like that.
    its the smallest router I own but powerful for its size.  I bought it for small jobs, but it handles most guitar routing without issues.
    before I got that I was mainly using Axminster white ones.  Okay for the price, still have one in the router thicknesser
