Pretty pictures of stuff and things here...
My Feedback thread here...
You will want some sort of reactive box, the resistive ones lose a lot of detail in the sound (which could be countered with a bit of EQing before it hits your speaker simulator).
The best solution for speaker simulators these days is an impulse response, perhaps something like the AMT Pangaea?
I haven't used one, but I like the concept.
I use a Sequis Motherload Elemental. The onboard analogue emulation is useable but I don't love it. I take a signal from the FX send and add IRs for recording, and I've had some killer tones.
What I do is send the signal into the loadbox, then take a DI from that and send it through an impulse in my DAW. Both the PDI-03 and PGA-04 have facilities for this (I've had both). At this point, I'd only recommend a Two Notes over them or similar devices, like Suhr 's Reactive Load, or Koch's Loadbox II, if for some reason you can't or don't want to have a DAW in the mix. Otherwise , so long as the device has a reactive load, they're all going to sound the same. I say that because a reactive load being better than a resistive load the received wisdom on the internet, however...
The CabClone is s resistive load, and I did a comparison between it and my Palmer, which is reactive, using both devices in-built simulation, and they basically sound the same to me. Neither sounded good, and shared a very similar characteristic. The CabClone I used is the one built in to my Mesa head, which only has the simulated output. But the standalone one has a separate unfiltered output that you could apply an impulse to. I haven't heard anybody try this, but I bet it would basically sound indistinguishable from a reactive loadbox going through an impulse.
Can post the comparison video if anybody is interested.
I would absolutely recommend the following:
If it doesn't need the Load Box element, the Two Notes Torpedo CAB is also excellent.
My music:- https://soundcloud.com/hubobulous
The built in simulation of the Palmer was pretty crap, it's just a high frequency roll off like most of the other ones out there. It doesn't surprise me much that with that sort of filtering that the reactive vs resistive load doesn't sound very different. Using IR's is a completely different kettle of fish though.
Here's a good example (not mine) of someone switching between a reactive and resistive load box through IR's:
Edit: Relistened to that clip on my monitors, and the resistive load sounds like it could sound very similar to the reactive if an Impedance Curve impulse was added to it, like the ones Redwirez includes in their packs.
http://amtelectronics.co.uk/accessories/pe-15
Mine just turned up today, and it compared very favourably with the 100W load box that randomhandclaps made for me. I'm going to be doing a demo video at the weekend with the JCA50H and JCA22H. Also, if you want one of those, use the coupon code "FB10" for a 10% discount exclusive to Fretboard members.
For the cab emulation, I use Two Notes Wall of Sound III in Reaper ***. I use the Buddha 2x12" cab model in stereo, along with left/right room impulses from the RedWirez Mesa V30 pack.
All told, that's the same functionality as a Torpedo Live, but for about £110 as opposed to £650. If you only want it for home/studio use, it's a no-brainer.
EDIT ***: On a personal note, the shocker here was that Wall of Sound III actually works under WINE in Linux. That might not sound like a big thing, but trust me...it was almost as surprising as BFD3 working.
