If a replacement was fitted, ask if the original is still with the amp. Shouldn't cause any problems though, if it was done properly.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
People don't like to do it because of 'originality' - and because it can be badly done if the right type of transformer isn't used, or by someone who doesn't know how to do it properly.
Unfortunately that applies to the one on Ebay - in fact it's actually dangerous, given that the primary transformer taps are exposed on the outside of it. Gaffer tape is also not a proper mounting material, which leads me to think the chassis has been hacked to fit it and hence it can't be put right even if you got the right transformer.
http://i.ebayimg.com/images/g/bqcAAOSw5cNYPFSr/s-l1600.jpg
I'd want more pictures, especially of the chassis from the inside, before I'd even consider it.
But it's ludicrously overpriced anyway, so don't bother…
Shame.
Rift Amplification
www.riftamps.co.uk
RiftAmps is right, it's a shame - sadly not unusual with a lot of old 'repair' work we and the other amp techs here will have seen. Back in the 60s/70s/80s, there was no concept of trying to keep something original, or even caring whether an amp had to be drastically hacked to fit whatever near-equivalent (electrically - not necessarily physically) transformer was to hand if someone needed to replace one.
You will often find in cases like this that the original cutout in the chassis has been crudely enlarged, and/or extra bolt holes drilled to mount the new (usually second hand) one across it. The base of the transformer being wrapped with tape looks to me like someone has tried to cover an ugly gap. The exposed primary terminals are really dangerous - all you have to do is put your hand up there when the amp is on and you'll get a direct shock from the mains. What's almost as worrying is that it appears to be wired to the 200V tap not the 220 or 240, which means the transformer will be running very hot, as will the valve filaments.
Given this I would want to see very detailed pictures of the chassis, inside and outside, before I would want to make any offer for the amp at all. There may well be other 'repair damage' inside too.
That's indeed a bodge, aka an "improvement".
Not withstanding the hazardous nature of the repair, it's quite possible that the voltages will not be correct either.
This will need sorting out, and as ICBM et al have commented above, they chassis may have been modified meaning it will require some jiggery pokery to get a repro mains transformer into the unit.
£3.2k is "optimistic". That's would, in my opinion, be all the money for a very good - mint BFDR.
For example there is a very good sounding 60's BFDR in Regent Sounds at £2500 with original transformers and 60's Jensen speaker.
I'd say that amp is worth £1000 - 1200 tops, depending the extent of the "modification".
There are now plenty of suppliers of reproduction transformers that will fit into vintage Fenders with no modification to the chassis, so it's now possible to convert an BF Fender to UK voltage by swapping out the PT without irreversibly modifying the amp.
£3200 is much too much.
£2500 tops- and then I'd want a JBL D120F in it for that money.
Rift Amplification
www.riftamps.co.uk
