Got my test on tuesday, not had a single professional lesson so I've been reading up on things that trip people up and found that I have to check my mirror after every gear change. I'd been told that the test was jumping through antiquated hoops, but it just seems to be an exercise in the most noddy shit they can think of.
Still, I'll now be ultra paranoid about observation which I could live without!
Ah well, any tips from anyone? I've got all day tomorrow to practice and I intend to use it.
Test centre is High Wycombe and the place is filled with utterly crap mini roundabout systems so I'll get nailed for observation I reckon, probably because I sniffed and forgot to shoulder check and file a tax return afterwards.
Still, my test is 9:37am so hopefully the will be some traffic left over to gridlock my half hour sufficiently that even I could pass.
'Awibble'
That said I'd imagine that missing the occasional mirror check is, at worst a minor fault. I think you'd need to be pretty much driving with your eyes closed (or checking your phone!) to get a major on observation.
Good luck with the test. If you don't pass this time I'd suggest getting a few lessons with a professional. Learning off parents/mates is a cheap way to do it but you end up picking up their bad habits and most us have more than a few of those after several years of driving.
Good luck buddy
Still, second time around I passed without hitting anything.
Bottom of marlow hill has been my nemesis, father has been forcing me round there for the hell of it.
I've noted that I only have to go where the examiner wants for ten minutes, after that I'm supposed to follow traffic signs according to a general direction, but I can't be failed on navigation so if he points me to Eden I'll bail and head somewhere else.
Only thing I'd say is make it obvious that you're checking your mirrors, e.g. turn your head slightly when you look, not just move your eyes.
Good luck.
I cant drive home from the test if i pass anyway, as passing invalidates my learner insurance such that I would need to amend it and pay about a grand...
Oh and best of British too
Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
Major faults are a straight fail. They are things like breaking the law, doing something dangerous, etc.
Minor faults are added up and you still pass if you don't get too many of those. They are things like failing to indicate when you should, or failing to check your mirror before doing something, or poor gearchanging, poor steering. etc. If you have several occurrences of the same fault (for example, failing to use your mirrors) then that will be upgraded to a major, as it is a consistent fault and not just a one-off under stressful test conditions.
If you're able to control the car, make sure anything you do is safe before you start doing it and don't break the law or hit anyone you should be fine. Just drive normally - don't be overcautious or too aggressive, just smooth and safe.
Let us know what happens tomorrow and good luck!
Sounds odd to me as well - like some regimented, formulaic way of ensuring the testee checks mirrors regularly.
Arguably, you should already have checked your mirrors if you're planning to accelerate or slow down, and that should have been done before any gear changes to assist the change in speed (because they come after the decision to accelerate or slow down). There are also situations where a gear change might not result in a change of speed, such as getting up to 30mph in 3rd and then changing to 4th and staying at 30mph. You should already have had good awareness of what's going on behind you when increasing speed in 3rd.
Nomad
My feedback thread is here.
I would also add to make sure you indicate in good time before the corner. Thats the one that almost got me. 1 more strike on that and I would have failed.
Its the minor stuff like that that will get you, not the main manouevres.
Mirror checks are a classic example. There's no rule about checking before every X, or after every Y. But you could easily take that kind of rule and make it work for you, but it wouldn't be making you a better driver.
The best tip I can give is to plan ahead. If there's something that is likely to cause you to change speed or direction, then you should prepare for the worst case - i.e. be able to stop safely. To do that, you'll need to make sure there's nobody following too closely (rearview mirror), or if you expect to steer into a different lane then check the relevant side mirror. Adjust your speed accordingly, so that stopping is possible and work up from that.
If you treat mirror checks as just a thing that you have to do to pass your test, then you'll probably do them wrong. Instead, think of what you'd do differently based on what you've seen in your mirror. Is the car behind too close? Is there a cyclist on your right hand side as you approach parked cars? If that information means you need to do something different to the normal, then you'll need to have given yourself plenty of time to do it. And that time comes from planning ahead.
The driving test (my experiences were actually for motorcyclists, but it's the same thing) is an imprecise tool. I've known examiners who failed really good riders because they were forced to - the candidate rode brilliantly yet made a silly mistake. They've also told me about candidates who they were forced to pass because they were lucky - even though they were convinced the candidate was a crash waiting to happen.
Nil Satis Nisi Optimum
What's the reason for not having lessons?
That doesn't make sense. As soon as Hertz32 gets in the car he checks his mirror. Then because he's done something, ie checking his mirror, he has to check his mirror. Then because he's done something, ie checking his mirror, he has to check his mirror. Then because he's done something, ie checking his mirror, he has to check his mirror. Ad nauseum
He's not even going to get the key in the ignition if he literally checks the mirror!
@RaymondLin , I quite literally believe that you are misusing the word literally. :P
