You need an idea of what you are going to do, but it should be a vague idea.
My feedback page: http://www.thefretboard.co.uk/discussion/91654/
In the FAQ it says under 'What to Avoid':
- A FET compressor is a powerful form of compression, due to the fact that it can respond so quickly. However, this isn’t always a good thing and when used with guitar it’s very easy to select settings that result in audible distortion artifacts.
- When compressing you’re essentially attacking the waveform, and so you must be careful not to gouge out large chunks! Dialing in high levels of Ratio, along with very fast Attack and Release settings WILL result in distortion. These distortion artifacts will get more audible on lower strings, and when playing complex “jazzy” chords. For this reasons it’s often best to offset particularly strong settings on one of the Attack, Release, or Ratio controls, by dialing in less extreme settings on the other two knobs.
Don't know if that helps! I'm a novice when it comes to FX. I just play and if it sounds good, I'm satisfied ;-)You need an idea of what you are going to do, but it should be a vague idea.
By adding mids I mean more that this is what most cmopressors seem to do by default. You lose the very top end as soon as you switch then on and then more and more mids come in as the ratio is increased. If the Cali circuit doesn't do this then it will sound very different from the comps I've used.
