IT types - bit of help? (network switches)
TimmyOTimmyO Frets: 7546
So, my broadband cable router has 4 ethernet sockets, and all are currently busy (power line adapter, tv, sky box, console) and I'd like to keep those devices cabled.
I also want to have a bit of a dabble in smart home stuff - Sonos, Hue, Nest and whatnot. Most of these things seem to require, or work best when, their own 'hub' is plugged in to the wifi.
So I want to add a bunch of ports.
Looking on Amazon there are options for under £20 that will give 5-8 sockets - but I might be being dumb but none of the sockets look to be a designated upstream connection to the router - does it 'just work' however you connect it or do I need a particular type of switch?
thanks in advance
Red ones are better.
  • octatonicoctatonic Frets: 33837
    edited December 2016
    Yes it should just work- at least if you are buying something reasonably new.
    This is how you connect a switch to a router:
  • SporkySporky Frets: 28664
    Ah; the joys of configuring Cisco ports.
    *shudders*
  • Myranda said:
    dont buy a cisco switch unless you really know what you are doing with it. It isnt a plug and play device
    +1 on giving Cisco a miss.
    Get a £20 Netgear or D-Link switch- they are pretty much plug and play.
  • MyrandaMyranda Frets: 2940
    *shudders*
    I would say "they're not that bad" but with 8 degree students on the Networking Theory and Technologies module unable to finish the "configure a router with 3 ports (2 serial an 1 ethernet)" test ... maybe only if you have the ability to type a few lines of text.
  • quarkyquarky Frets: 2777
    I have my old Sky router and my current Sky router connected. I can't remember which port I used, but in the old days, a port used to connect to another router rather than a device needed to be on a particular port (ie, the first one or the last one). I think I have mine plugged into the last port, but it just works basically. Joining the two up gives me six ports rather than four (four+four-two (for the connection between them)) for one of them..
  • TimmyOTimmyO Frets: 7546
    cheers
    I'm fine with a good eight or ten coding and/or scripting languages. But even after doing ICND I find Cisco stuff ridiculously illogical, inconsistent and painful to configure. It baffles me that anyone still buys the stuff.
    Doesn't/didn't @clarky write low level protocols for Cisco gear?
    I mean...
    en [enter] <[password]> [enter], gi int [enter], ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx (ip address then mask)[enter], exit [enter]
    is hardly unpossible to type...
  • ClarkyClarky Frets: 3261
    ahh.. sorry guys.. I didn't write protocols for Cisco
    I have done some goofing with routers and switches years ago though..
    my knowledge is CCNA switching and routing and CCNA Voice level..
    and very rusty
    and Sporks is right… Cisco config is not a huge pile of fun
    the general rule of thumb [once the fundamentals are built] is to think of the OSI stack and build from the bottom up..
    Clarky said:
     the OSI stack
    Princess
    Diana
    Never
    Tried
    Shagging
    Prince
    Andrew
    is how I remembered Physical, Data, Network, Transport, Session, Presentation, Application :-)
    Had to happen sometime.
    GUIs exist.
    Also the different syntax for different devices is daft.
    GUIs exist.
    Yes, router and switch having slightly different syntax for the smae thing is silly
  • ToneControlToneControl Frets: 11969
    Wouldn't you put the server on the same switch as the PC(s) if  it's mostly (or entirely) used for local backups and local storage (like mine is)
    Myranda said:
    GUIs exist.
    usually the result of completely different teams developing stuff [different devices or different software blocks within the same device] without having standards / conventions defined [imposed on them]..
    you see that sort of stuff all the time..
  • Emp_FabEmp_Fab Frets: 24429
    Buy any old crap and plug it together. It'll work.
