So a 16-ohm amp into a 16-ohm attenuator into any speaker cab is OK, as long as the attenuator is set to at least -6dB - which it almost certainly will be with a SLP!
The Hotplate is not the attenuator of choice for a SLP - it's not great for Marshall-type and Vox-type amps in general, although it's very good for Fender and Mesa. It will stress the valves quite heavily with a SLP if you're cranking it.
The Marshall Powerbrake only has 16 and 8 ohms, not 4, but it's a much better choice for this amp.
Not tried it with a Marshall though.
Thanks for the advice, I had a powerbrake with a 1987x a few years ago and it worked well, its good to know whats the right kit.
