This question really needs to go to Fryette, but I've never had an email response from them in my life and right now, they don't seem to be keen on picking up the phone either, so I'm hoping someone with a broad technical knowledge might be able to give me a pointer..?
The Power station has an impedance matching function, so you can set the input to match the amp and the output to a different impedance to match a differently rated cab
As I understand it, this is done via a transformer
I'd like to use this matching with the Power Station in bypass - so the question is to whether I can use the Power Station to avoid an amp / cab mismatch in standby?
This is only to run a 16 ohm speaker to an 8 ohm cab, so it's no doubt OK, but I'd like to use the PS if I can?
cheers
Baz
If it physically bypasses the circuitry and connects the output directly to the input - which is what the manual says - then you will have a mismatch. In practice this may not matter anyway since most valve amps will tolerate a 2:1 mismatch in either direction, but some don't like it.
If I get a definitive view from Fryette, I'll post it back for prosperity
You may get a faster response by posting on one of the Fryette threads on TGP, where they spend some time trying to keep the fanboys happy (as long as they don't ask awkward questions).
i think I'll pick one of these up this year, despite that though.
To be fair they've been responsive in the past to me before. Just not in January...
..reckon I've emailed or rang them 15 times over that period and I'm none the wiser!
..ironically, I've never had any problem getting a response from Lean Business
@moe_zambeek - TGP is a good shout - ta
