Audix I5
If you do need a stand you can get a very compact short jobbie from Thomann (and probably elsewhere) that has a heavy base instead of a tripod. Far less of an intrusion on stage or indeed for recording.
Dave.
https://m.thomann.de/gb/superlux_pra_628_mkii.htm?gclid=Cj0KEQiAzNfDBRD2xKrO4pSnnOkBEiQAbzzeQXAfoTWKa85meyYyKKfyMojoMO4OP98_cPhRIFy5hksaAres8P8HAQ
I've got one of these and, after I got the hang of recording, got some really great results. Plus no mic stand needed - just hang it over the front. It's directional so it seems to reduce the amount of noise that gets through.
Consider also a DI box like the Palmer PDI09 or Radial JDX.
https://www.amazon.co.uk/Short-Desktop-Microphone-Stand-Straight/dp/B000LAKS8I
Sadly the non-tripod version I have seems out of stock at Amazon but Thomann have them albeit more money.
You can get a round, heavy based stand but they are not quite so stable.
Oh yes! (fergot, no Joe yet!) Checkout Orchid Electronics for DI, Re-amp boxes and the like. Every bit as good technically as Radial, lot cheaper!
Dave.
http://www.soundonsound.com/reviews/prodipe-tt1
@simonk @ecc83 - confession time - what's a DI box? That's direct input to the mixer right? How does it take the signal from the amp?
As as I understand it once you've fixed it in place ( maybe just some Velcro) and plugged it in you can just leave it there for ever wether you use it or not, all you need to do on a gig is run an XLR lead to the PA. You are, however, hearing your amp via a speaker emulation rather than a mic'd speaker. Which may or may not be a good thing.
