If you're vaguely competent with a soldering iron and a drill it's easy enough to build one in a few minutes with less than £10 of parts - it's just a 100k logarithmic (audio taper) pot and two jack sockets in a box.
Our flat is 5m x 2m and it works fine here.
Have you tried fine adjustment on the volume control? Mine is quite sensitive but it's possible to get it just right.
There is a mod for the hot rods to replace the volume control with something less aggressive - Fromel is the company in the US or show the Fromel stuff to your local tech and have him do it for a lot less !
Also what speaker are you using? A decent speaker can have a dramatic effect on an amps useability.
The volume box that was popular a couple of years ag is the EWS subtle volume control. They were around £50.
Or you could do this:
Hope you work something out, the MK III is a really great amp.
Good luck.
Good luck.
If you're not able to make one yourself you can easily buy them online for a little more than the cost of the parts - like this one:
http://www.ebay.co.uk/itm/Guitar-Amplifier-Attenuator-Volume-Pedal-Passive-Volume-Amp-Reducer/141620893968?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=2&asc=40800&meid=8306de4be816474489d966b4e1b7a781&pid=100005&rk=3&rkt=6&mehot=pp&sd=252712286090
That's quite a bargain, if you work out the parts cost and factor in the time to build it.
Once you can turn the master volume up a little further you may even come to like the overdrive channel .
That might be terrible English, sorry.
For £20 more you can buy a GE-7 which will do the same job *and* give you a final EQ at the end of the signal chain for the effects loop.
My local Tech quoted me £25 inc labour to build me one. £10 parts and £15 Labour, which is his standing min rate anyway.
I think even I could build one of these.
I like the look of these.
One of the OP's questions though was whether such a device could used together with pedals in the effects loop - I too would be interested to know if is it safe to do that?
If you have a pedal in the loop which has low headroom and overdrives like that (eg an MXR Phase 90) it would be better to put the volume box first after the preamp out.
Only problem then is getting the level back up to go to the return. So you either crank the amp's master volume, or use a boost of some type last in the chain in the loop.
Also, if you have a spare pedal with a volume control, or a spare volume pedal, then you don't need one of these boxes.
It's all so cack-handed though. One device to drop the level plus another to boost it back up, stupid. Amp manufacturers need to get with the program, we want adjustable instrument level in loops, we want to use pedals in loops not rack units, it's not the 80s any more.
Sorry, fxxks me off.
