As a tool to reduce room ambiance, they're not so great.
Why?
Well, for a start, they're behind the mic, in the area where most vocal mics are naturally less sensitive. Room sound also arrives at the mic from the same direction your voice does.
Second, it's pretty much impossible to make a reflection filter that absorbs all frequencies. For lower frequencies it'll be as if the filter isn't even there, and there will be some frequencies that bounce off it, back into the mic. Have you ever heard how weird sound can get when you have a curved wall? What you're doing is creating a little parabolic dish that concentrates certain frequencies by reflecting them straight at the mic - so you get little peaks and dips through the midrange.
If you think the floor is going to be an issue, you could probably do more with a rug IMO.
Sound on Sound did an interesting article on them a few years ago. Annoyingly I can't find it.
Bandcamp
Spotify, Apple et al
http://gikacoustics.co.uk/product/pib-portable-isolation-vocal-booth/
I think they are a solution looking for a problem really. You're better off hanging a couple of heavy duvets behind the performer.
I use it with an Se condenser and it's all fine though I did a vocal last night with an SM58beta , no filter annnnnnnnndd.....it sounds fine !
result.....I wouldn't bother buying one.
https://twitter.com/spark240
Reddit r/newmusicreview
Bandcamp
Looking around the loading bay we gathered together 3 sheets of ply. We battened those with 2" x 2" and then covered the wood in Rockwool acoustic slab, which was then covered in black cloth. That thing worked amazing well and enabled us to record bone dry vocals in a large reflective room I designed for large drum sounds. All it consisted off was £30 of rockwool covered with cloth
For vocals though, I've found they generally cause more problems than they solve.
Website || Feedback Thread || PayPal
