new to the market, check out the demos, looks ace!
we'll be getting them in stock next wk, but magnetic have them in now.
However, none of these are designed for Line level - but if it's to go on your pedal board I'm unclear as to why you need a pedal designed for Line level - I thought it was only rack units that were designed for line level?
He is using the boost to overdrive the amp. All the drive is coming from the amp, not the pedal.
For clean tones check out this video.
1) Rack TC 1220 Para EQ
2) The pedal version of the 1220 DUAL Paramet EQ
Out of interest, for the boost, have you thought about just putting a patch cord in the loop and set the loop level lower, then step on your loop bypass switch to get back to your higher (normal) level?
In other words, you don't need anything in the loop, just use your loop level knob for the volume difference you want.
http://www.revivalelectric.com/metric/
They also now do an even smaller pedal form but that probably won't have the full control you're after.
The Empress Paraeq may also be worth a look. I think that can have the voltage internally changed to alter headroom if I remember correctly which may help with line level. Plus there's a separate boost mode which is footswitchable.
I have a Van Weelden Twinkeator for sale, thatll do exactly that
