Yes, it looks like a toy, especially if you have the matching cabinet .
It does not sound like a toy - it's a genuine 200W output. It also weighs less than 10lb.
If it has a flaw it's that the cooling fan is very noisy, which makes it less useful as a home amp than you'd think from the size.
Away from Orange, there are loads of options for lightweight/class D heads, depending on your budget and sound. You might want to look at GK or Ampeg, perhaps?
http://www.thefretboard.co.uk/discussion/57632/
Loud, punchy, clean or warm or filth.
Amazing amp.
How do you use it? What kind of music do you play?
There is a jazz demo of the amp around too.
I use it clean mostly or with the vintage circuit on a little so it sounds like an old Ampeg B15 or a Dan Armstrong amp.
300w into 8 ohms, 17kg weight and easily expanded with another 2x10 or 1x15 if required.
Excellent product. Just have to watch out for the weights. The website still shows the old Italian build weights. The Indonesian ones are significantly heavier.
The DG is 2.9 kg and the Barefaced cabs I use are 7.5kg each.
I have a pair but 1 is significantly louder than the MB.
