Mine is a US made one and I have no experience of the Chinese ones. You can pick a US one up for around £300 second hand anyway.
IIRC his issue was that it was one of those amps you need to push a bit to find the sweet spot and outside of that a bit bland. This wasn't always practical and he ended up with a Fender HRD which he found a bit more flexible.
This is my mate with one leg so he doesn't do pedal platform amps!
A bit like the difference between a Blues Junior and a Hotrod Deluxe...
It sounded pretty good and it w5as loud but I don't think the stock speakers really showed the amp at its best.
The 2x12 is definitely more manageable and also sounds good. These can be found fairly easily now for around £300 on EBay or maybe even a bit less.
Its interesting that because more and more players are looking to simplify and reduce the weight of their rigs with small amps or mfx units, the demand and thus used prices for amps like this have fallen significantly. The new price of a Peavey Classic 50 2x12 is around £1,000. But why on earth would you spend £1,000 when you can buy a used one for £300. Even if you had a service, replaced the valves and upgraded the speakers, the most its going to cost you is around £600 in total, or maybe £500-550 if you buy used speakers.
