Actually there are plenty of people who run a DR with a 16 ohm speaker as the reflected impedance will be more "correct" when using a 16 ohm speaker, so this is fine.
My belief is that the amp was originally intended for 6L6s - the ratio is close to correct for those, with an 8-ohm speaker - but Fender then realised the cheaper 6V6s would do the job.
It's also interesting that the "characteristic 6V6 sound" which most people think of is the Deluxe, but that famous 'flubby' tone is as much to do with the impedance mismatch as the valves.
