Because I am bored at work, I have nothing better to do than pester this parish of knowledgable legends so i don't have to wade through a veritable mass of utter bullshit elsewhere online to find this information.
With that said, I have only ever had 2 channel valve amps, and the '68 Custom Deluxe Reverb is, from valve point of view, a different kettle of fish.
So, what would you recommend I revalve it with? Given that it is a noisy amp, 'low noise' valves for the Reverb and Trem bits would be good, if such a valve exists.
Should I stick to one brand? Mix and match? I already have a few valves left over that are already in it, namely an EHX 12AH7 and a Philips NOS 12AT7. The other valves are stock Groove Tubes which appear to be rebranded JJs after some inspection.
I've had the amp for about 4 months now; but I believe it is coming up to it's second birthday.
Bonus question: The glass fuse blew last night; not sure when, but I switched it off and then 10 minutes later came to switch it on and it was dead. The fuse had blown. Anything in particular I should be concerned about? My Dad is convinced 'fuses only blow for a reason'...
Thanks in advance. And maybe sorry in advance too
You can experience "nuisance" blowing of fuses, however if a fuse blows persistently then there is a problem.
In a valve amp this is usually due to a power valve shorting.
I've not seen many 68s, but they don't strike me as that noisy.
Usually the valve at the start of the signal path have the greatest effect on noise.
In my experience their aren't any brands that are less noisy than others; if you want low noise valves then they need to be selected for low noise. You will of course pay extra for this.
As you have seen with Groove Tubes, many valves are simply rebranded from one of the 3 or so factories still making receiving valves.
Of new production I like EH-12AX7s in Fenders. I've also had good results with JJ 6V6s.
Fuse value selection is more art/experience than science. The designer cannot allow for every eventuality.
If a fuse blows in a particular position a few times a year and there is no obvious cause it is usually in order to move up to the next preferred value but try to contact the manufacturer first to establish, 1) that you have the correct value and type in the first place. 2) They don't tell you absolutely not to do it!
Dave.
Put the Philips 12AT7 in the phase inverter position (V6) if it isn't there already, it will have the most benefit there.
The main reason this amp is noisy is the reduced negative feedback compared to the original version though - it's intentional to create earlier breakup and a more 'driven' sound, but it also noticeably increases noise.
This fuse looked perfect but tested open circuit. I replaced it with the same value and ran the amp literally wide open - gain and volume up full and tone where it seemed loudest - for about 5 minutes. No repeat blow even though the valves were looking really quite stressed.
