On the downside,that's a shit load of visits to the local 99p store.
http://www.pistonheads.com/gassing/topic.asp?t=1498745
Has some tips and comments are useful. There is a pebble version mentioned. Test the self levelling has bond well if you use that which you probably will.
If you have wooden floors as mentioned in the comments then expanded metal lathe screed down and a very thin screed or self levelling should be crack proof or more to the point it won't move if it does crack do shouldn't propagate up to the coins in resin. If self levelling is used make background spotless and use Feb bond making sure you apply when tacky - instructions are important, you don't want to be ring that lot up.
I will never use laminate flooring again. Proper wood or decent lino ftw.
(like that @axisus ?)
