Abandoned project. Content removed
axisusaxisus Frets: 28338
edited October 2017 in Making & Modding
Went wrong several times. Got disheartened with it. Project abandoned but bits being recycled.
  • So, just a modest spec, then  ;)
    I like all of the above VERY much.  I, for one, WILL be following the blog (or why not copy and paste here? Hint,hint)
    Pop corn  by the side, easy armchair ready :)
  • RockerRocker Frets: 4985
    I love the idea of Chinese number inlays on the fretboard.  Good luck with the build.
    Nil Satis Nisi Optimum
  • 4xv4xv Frets: 49
    Be interested to see this come to life, I too am about to embark on a second scratch build having learnt lessons from the first build I'm hoping the second be a vast improvement. Where did you get the sustainiac from btw always fancied putting one on a build.
  • axisusaxisus Frets: 28338
    From our pal Jonathan at Feline. Darned expensive!
  • FelineGuitarsFelineGuitars Frets: 11594
    Yes - the fall in value of the £ against the $$ has made certain imports cost so much more.
    In fact I've held off replenishing a couple of imported lines hoping that the £ may get some value back  via Trump's actions affecting American confidence.
  • Cool guitar - cool blog - good luck!
    Looks awesome!
    UPDATE: I have just found out something interesting! I can copy the blog info and stick it straight in here and it seems to retain picture links! This is waaaaaay less hassle than loading pix on a sharing site, copying individual URLs and sticking them into the posts. In the light of that (assuming that it does work) I will just stick blog posts straight into the thread.
    edited October 2017
    I have also been working on the wiring, which has proved to be something of a headache as I have no knowledge of the logic of wiring. The diagram that I have created is basically joining up the Sustainiac info with the Fishman powerchip and then adding in a 9-pin jack. I think I have arrived at a working diagram but it won't be put together and tested for some time yet. Many thanks to @ICBM for helpful input.
