I have the Peavey Rocking guitar from way back:
http://thefretboard.co.uk/discussion/53142/@TheMarlin upgraded with Compton bridge etc, . . . An excellent guitar. Intonation is perfect now and a slight shim in the bigsby means the strings align perfectly [now I know the hassle of floating bridges and why they have decided to pin them
:-) ] I am starting to bond with this guitar now as I wasn't used to a Gretsch huge body design. I even decided to try some Gretch Guitars out to see how much Gretsch tone the Peavey has.
@TheMarlin was of course correct, the boutique pups matched at least the Gretsch 5420s (I couldn't A&B) but I did find the necks on the new guitars were lacking wear and felt grity. The Neck on the Peavey suits me better, slightly thinner.
Question: I don't like the knobs on the Peavey. This is subjective but I can see the nut below the knob and IMO the knobs are too large [enough with the phnaar phnaar please :-) ] I know about strats etc but can I replace the knobs on the Peavey with say Gretsch knobs? I'm not trying to pass the guitar off as a Gretsch or try to make my Peavey into a Gretsch i just think a design fault In my opinion - just not smooth enough for me.
I'd like this change to be reversible if poss.
The pot itself is fastened by a washer, then a nut on top.
To remove a knob safely, you can slip a piece of cloth underneath like a 'sling' and lift up gently.
Some metal knobs have a small grub screw in the side, so check that they don't have one of those first.
Anyway, glad you are getting on with it, and it should be really easy to change the control knobs, either just pull off, or with some types, there may be a very small retaining screw - I really can't recall with that one.
I couldn't get on with the flatwound strings that were fitted, and still have a couple of similar guitars, so I'm glad it found a new home, sounds like you are gradually getting it just the way you want it!
I'm glad you are liking it.
I can't believe it's been sold so many time since I had it.
It was a nice guitar.
Cheers for confirmation - so standard method then.
@musicman100 Yep you aren't kidding, it must be one of the most photographed on the web on a parr with Springstein's tele I think :-) I did a search for Rockingham and it shows up in a few places - I tracked the checked the grain on the body.
@Richh I think flat 11s weren't they? They are incredibly kind to the frets and I like the slinky feel and almost noiseless aspect but I'm better suited to 10s and the Bigsby is happy enough with that for my style.
I buy guitars when money is good, and sell when it's bad. I don't do it to make money (I never make money on guitars), I do it because I love guitars.
This Rockingham is a fine guitar.
Note. Get some cello rosin. When you next change strings, rub the bridge base with rosin, then restring.
It wont move again, and it won't affect the finish
enjoy
Marlin
Especially for string bending, I just couldn't cope with them. Maybe for jazz or something...
I like the woody tone of flatwounds with P90's. They don't sound good with humbucker though
Yep agreed strings are cheaply usually I will treat my guitars with new strings regularly. Those Thomastik flatwound are are a different story. They are now £20 on amazon for a single set. Thomann do them for £14 but £10 shipping!
I'd be tempted to try flats on some other guitars, as I have P90's on some, and love them, but if they are that hard to bend on, I don't think I could handle it.
I really don't think I'm weak I was raised on a building site. A whole tone bend at 12th fret G string is okay however a semitone on the G string at 4th fret is hard work. I started to use a different set of strings for 1st 2nd 3rd E B G so ordinary non wound strings for those and then 10s Flat wound for the 4th 5th 6th D A E. I liked that setup and the tones.
