hi all about 6 weeks ago I posted that I was having a buzzing from a new build I am doing it was suggested that I shield the cavities. I have stripped all electrics out and painted cavities with shielding paint, changed all the pots for new 500k mini cts, checked all my joints as I have gone for continuity and everything ok, followed the Seymour Duncan wiring diagram to the letter
and guess what......still a damn buzz....gets worse when you touch the bridge as it did, all volumes work again the buzz get worse when the tone pots are played with
what am I doing wrong!....help needed before I go mad
cheers guys
Have you checked you've got signal and ground the right way on the output jack?
Check for shorts rather than bad connections next, would be my advice.
yes it does get worse when you touch the bridge @Sporky
If it makes you feel better I did that a couple of weeks ago, I have no idea how! It's not like I haven't wired thousands of jacks .
Note to oneself more hast less speed....oh and check the ground before wiring a Jack
thanks guys your correct the jack was wired the wrong way
Still not sure how I did it, but these things happen...
