So in the last 12 months my 2007 Focus 1.8TDCI has had the following:
New Clutch and DMF
Replacement Starter Motor
New Bearings front and rear
Replaced split turbo hose
It's also been hit up the rear and had a replacement tailgate, rear bumper, seatbelt and towbar !
So last week I started the car (with the door open) and the LCD part of the dash displayed "drivers door open". Shut the door and that message is now permanently scrolling left to right along with the mileage in the background - meaning I've no idea how many miles I've done on the trip or the odometer - brilliant !
Took my daughter home on Saturday and on the way back on the M3 the car decided to go into limp mode. No warning lights on the dash but wouldn't go above 55mph. Using more than around 40% of the throttle causes it to cut the power/fuel. Seemed ok the next morning until I hit 73mph (ish exactly 120kmph) and this happened again. As long as I keep it under 70mph the car drives fine, turbo is boosting normally etc.
Car is booked into the garage tomorrow but I'm feeling this is going to be something horribly expensive.
A place that you send your dash off for repair have suggested the error with the dashboard may be causing it to enter limp mode but I've not heard of this and neither has google.
Fed up of this car costing so much money. I simply don't have the funds to purchase another vehicle and rely on my car for commuting and also seeing my daughter.
We had to replace the alternator, a part of the suspension, get new fuel injectors installed at vast expense, the rear wiper motor burned out, and we, too had limp home issues for the final 18 months we had it.
What I found was that it only went into limp home when using lots of throttle in higher gears - so, joining a motorway and accellerating hard in 4th or 5th gear would do it, going up a steep hill likewise. So I learned to avoid that. We had it in to be looked at in ford dealers 3 times, they did stuff to the EGR valve, associated cabling/ pipes, turbo air pipes, replaced sensors, never fixed it. It's a shame because when it worked I liked the car, but I wasn't sorry to see the back of it.
To be fair, the Y-reg 1.8 TDI I had before that also had its share of problems, including but not limited to sticking accelerator pedal (free cruise control!) and the front passenger footwell eventually turning into a swamp thanks to a leak somewhere behind the dashboard that let water in.
Bandcamp
Spotify, Apple et al
My uncle had problems first where he had to replace the starter motor as it wouldn't produce enough power to start the car. After that the clutch went while on a Motorway, quite dangerous.
My sister had to replace her clutch as it went while doing 5 miles per hour through a car park. It was a multistorey and she got stuck trying to make it up the ramp.
I also forgot to mention the gaitor round the gear stick has come off and it keeps blowing bulbs for some reason.
Clearly I bought a lemon than decided to die 2 weeks after the warranty ran out.......
Apologies as that doesn't help your case! Just surprised to hear you've had lots of issues with yours!
I'll keep my fingers crossed for a cheap fix for you!
"You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
In all fairness though in the 4 years i've owned it it's gone straight through every mot, and only ever needed a bottom ball joint.
But lately it has been feeling baggy and old, and i was idly considering moving it on as i fancied something a bit younger. Then the headgasket went...
Electrical/computer stuff going wrong is tiresome. Problems can often be caused by a leaks around the windscreen/bulkhead allowing moisture/water into dash/fusebox/electrics.
only in the last year did it start to get the periodic turbo issues that made it unreliable . But 13 years of good driving was a good return
It's a very efficient engine ( i was getting 55+ mpg round town, lots more on a good run) but it's very fragile.
Probably no coincidence that it was developed with 'help' from Peugeot/Citroen......
A few years back i had a MK1 Focus 1.8 tdci, and that was great. Had it 4 years, loads of miles, never went wrong and was better to drive than any diesel family car has the right to be. In fact i'm thinking of going for one again.
Battery - only the second replacement it's ever had, so can't complain too much at nearly twelve years old.
Radiator - original, rusted through - of course a major job involving taking the whole front end off.
Exhaust tube containing catalytic convertor - at the manifold joint… at least it wasn't the manifold.
Driveshaft boot, broken suspension spring and corroded brake pipe, for MOT.
Not giving up on it yet though. It seems pretty solid otherwise and runs very well… although as the mechanic says, at this age the other front spring could break tomorrow, or something else. But it's only cost about two and a half grand in repairs in eight years, so it has some way to go before I'd consider it unreliable.
