To switch the volume pot value, you need to add a 470K resistor from the volume pot hot to ground when the coil split is active.
It may be easier to wire it by connecting it the other way up though, and combining it with the coil split - the red wire to both bottom terminals and the 470K to the middle one on the right, then the coil split wire from the pickup to the middle left. That will shut off the 'slug' coil of the pickup and leave the 'screw' coil active, if it's wired the standard Gibson/Duncan/Dimarzio way.
