Had the neck off my 64 P bass to adjust truss.
Nice clean neck pocket, tight fit too (!)
There's a shim in there, which is clearly there to lift the saddles only when on super low action. I like the action with it in and that's fine.
The shim is a heel end piece - loose and all that. Looks like it's been in for a while.
I know shims can cause a bit of neck ski ramp over time, so the question is, would I be better replacing with a full length wedge shim?
If yes, does anyone have any clue where I could get such a shim made up for a P bass that was really thin at the wedge end, going down to nothing at the other end, and prolly out of maple?
Or should I leave it and not sweat it? There's no obvious ski at the moment, but over time who knows..
http://www.stewmac.com/Materials_and_Supplies/Bodies_and_Necks_and_Wood/Electric_Bass_Bodies_and_Necks_and_Wood/Bass_Necks/StewMac_Neck_Shims_for_Bass.html
Half price shipping to the UK at the moment too.
All of my bolt on instruments are shimmed currently, I prefer the feel when there's a bit more break angle at the bridge.
I will prolly leave it, but going to see if a full length shim might be available
Ta!
Another quick truss tweak for the lower tension, and I'm rocking a .005" relief and approx. 4/64 across the board. Tad more on the E, tad less on the G.
I don't know if it's the TI flats or the lack of shim but there's more sustain to my ears, it feels even more solid, and it does genuinely feel a bit different. Wow.
