Feedback
Yes id agree with the others.. It goes a long way and it does start to degrade a bit once opened...
Also just in case you didn't know, some safety advice... If you use some old rags to wipe the oil on DO NOT just throw them in the bin when you have finished while they are wet.. Its been known that while the oil is drying on the rags it can cause a chemical reaction and it starts to heat up and can start a fire if a load of them are piled together...
When you have finished with the rag leave it out and lay it out flat to dry, and once they are dry you can then throw them in the bin... I have now taken to using paper towels like kitchen roll.. and once I am done with a piece I flush it down the loo![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
Just make sure they are nice and thick.. If they are too thin it just starts to break up all over the finish.. Like toilet paper just leaves bits all over the finish. You may want to try on a test piece of wood first
My Youtube page
http://www.axminster.co.uk/liberon-cotton-rags-ax21801
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
sounds like I am being daft, but I usually have plenty of both.
Instagram
Also store your bottle upside down if you're leaving it for any length of time, the air in the bottle will form a film on the top of the oil, making it a bitch to get out plus it'll deposit small lumps from the edges of the broken film... I learned this the hard way!
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
