hi all
i've got a mexican strat ive modded. I replaced the pickups with a set of Dimarzio single coils.
the thing thats annoying is when i plug the guitar in, the sound is really low. when i play it it sounds tinny and distant. when i knock the scratchplate you get a jolt and and the guitar comes to life for a few seconds then fades out again.
today i double checked all the wiring and even changed the 5 way switch.....still the same. all grounds are fine. i honestly thought it would work this time. its flipping annoying!!!
previous to the replacement the guitar pickups were working fine
any ideas?
thanks
bad connection?
are you talking about the actual soldering? because i resoldered everything to the new 5 way switch. i haven't soldered anything to the volume pot, unless the pot all of a sudden became faulty
anything else i can try?
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
@FelineGuitars i kept the same wiring on the pots, all I did is change the pickups. I made sure the ground wire from pickups went to either a volume or tone pot.
The pickups are the virtual vintage series from the dimarzio if that helps
thanks
Does the ground wire to the jack also go to the volume pot, or to a tone pot? Ideally you want all the ground connections on the volume pot.
On a more serious note, check that nothing unintentional is on, or close to, the screening foil/metal parts. Particularly check for whiskers - and I don't mean feed the cat!
If the switch is fine then the problem must be between it and the output jack, so there is definitely a bad connection somewhere around the volume pot, and if the sound goes thin and weak it's more likely to be in the ground - an open circuit in the hot just gives silence.
pot is because the output jack ground was short but I will double check on the weekend. Do you think I should ground all the pick ups to the back of the volume up too?
If the output jack wire is too short to reach beyond the tone pot, you could connect the pot casings together with a wire to ensure a good ground connection - although in theory this could cause a ground loop if they're also making contact via the foil, it's the lesser of the two problems if the guitar isn't working properly! This is common on old Teles, Jazz basses etc when the control plate gets a bit rusted.
you mean like this
https://ibb.co/eCQ2Va
