Fitted cover for Matchless / Bad Cat heads, semi flight case for same.
Moe_ZambeekMoe_Zambeek Frets: 3423
edited May 2017 in Amps £
Hello all,
I have a fitted cover for a Matchless HC30 head - which should fit other full-size Matchless heads as well as some Bad Cats.
It measures 55cm wide / 27.5cm deep / 23cm high (21.65" / 10.8" / 10"), the handle cutout is roughly 13cm wide / 4cm deep, centred. When fitted it covers the head to below the woodwork but not to the same depth as the feet (so it doesn't drag on the ground). It's made from 10mm padded foam with a cordura-type outer which is very hard wearing. This was custom made for me by Jenart, who i've had other covers made by, and is a very good quality cover. Considerably cheaper than a hotcover, I'm after £25 shipped / paypalled. *SOLD*
For comparison, the sizes listed for the Bad Cat handwired head cabs is 21 x 10 x 10.5 and the Matchless HC30 is listed as 21.5 x 10.75 x 10.5.
I also have a semi-flight case that fitted my HC30 head. Imagine a normal flight case with hinged top lid but lined with furry material rather than foam. I don't know why they lined it with fur but it was good for protecting the head from dings and stacking in the back of the van, and lifted the cab just enough...I'm looking for £50 shipped and paypalled for this.
Pictures to follow asap...
Edit:
https://i.imgur.com/ZUyQHVq.jpg
https://i.imgur.com/To01Pvw.jpg
https://i.imgur.com/tcFAM6t.jpg
https://i.imgur.com/uU3kdKV.jpg
