Feedback
I have a Blues Jr III, I have only used it at low volume at home for clean sounds. I don't have any problems using like this except for the Master volume which is a bit sensitive, having found the right setting a little nudge and it becomes quite loud very quickly, but if you don't move it about it isn't a problem.
I would have preferred the Blues Deluxe, but as Mrs ROOG suggested that would probably have been a bit big, I wasn't in the mood to argue and neither was she!
I am well managed, although the flurry of ebay pedal purchases earlier this year have yet to be discovered. I wait in trepidation of the annual domestic accounts review!
I swapped out the Jenson speaker in mine for an Eminence Texas Heat and applied some of the BillM mods. These reduced the ice-pick and boxy sound considerably.
It works beautifully when over-driving the pre-amp. My preference is to keep the master on full and then use the volume to bring it up to the required loudness. This gives it a fatness which works great on the neck pup of a Tele.
As bertie says the Blackstar is more versatile. I too was looking for a Blues Deluxe (the gorgeous 'Smokey Joe' version) when I bought my BJ but Deluxe was just too loud for me.
