Electro-acoustic from Tanglewood's Sundance Pro range. The cutaway is an extra special "Florentine" design and the finish is satin matt giving it a great look without stifling any tone. It's good to see Tanglewood using Canadian cedar for the solid top construction, this gives an incredibly bright and balanced tone which makes it a pleasure to play.
Part of the warmness of the tone also comes from the solid rosewood back and sides as well as the bone top nut and bridge. The bridge and fingerboard are made from rosewood and the body is bound with maple. On top of all this the machine heads are gold Grovers and the inlays on the headstock, fingerboard and soundhole are a spectacular green Abalone.
The EQ used is the top notch B-Band system which gives a truly brilliant representation of this guitar's fantastic tone. When you plug an acoustic in you want it to sound as close as possible to the guitar's acoustic tone. The B-Band does this fantastically and needs to be experienced to be believed.
