http://www.mouser.co.uk/Search/m_ProductDetail.aspx?Hammond-Manufacturing/290DEX/&qs=itkJorDwoMLUjRRU2U+iqQ==
http://www.mouser.co.uk/Search/m_ProductDetail.aspx?Hammond-Manufacturing/1650P/&qs=sGAEpiMZZMv0IfuNuy2LUcyh5J80v/VukRtke9/AdqU=
Let me know if they're of any use to you.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
A 15w - 20w OT would be more than enough for a single 6L6, EL34, 6550. I use this on a number of builds that use a single valve, it is over rated and handles all "standard" valves easily and makes a very giggable amp
You can use multiple OT for multiple valves if you want.
http://modulusamplification.com/15-Watt-SE-Output-Transformer-P5295332.aspx
The Hammond 125ESE is what allot of guys were using 8 years ago when I was big into SE amps
I do agree with RiftAmps though, if you want more than 10w then PP is the way to go.
Rift Amplification
www.riftamps.co.uk
