Probably....
Recently (mid January) sold my lovely Vox AC30 Cream Edition (slightly regret it) and decided to go down the modelling route for a few reasons.
Lack of space at home now with 2 little'uns
Need for headphone practicing at home as per above reason
Wanted something more compact/portable
The other guitarist in the covers band I play in from time to time went out and bough an Atomic Amplifire, was blown away by it and on paper it looked ideal. He came round, I tinkered and tweaked his knobs (Ooer!!) and was pleasantly surprised. It ticked all the boxes, had plenty of fx to keep me happy if I chose to use them, the right amp models and more importantly sounded great.
Now 5 months on, I'm a dab hand at building my own presets, have bought a couple of preset packs and various packs of cabinet impulse responses. Overall it still sounds good but I seem to be tweaking tones 95% of the time I do get chance to play, rather than actually playing. Also, GAS is setting in as it always does and all I can think about is a nice valve combo with a couple of pedals.
Would it be crazy to ditch it and go back to a valve setup? Or is it a case of us guitarists are simply never happy?
Totally all I'm after is a Plexi/800 with a boost. A hint of delay. Nothing major. And that's all I'm really using in the Amplifire.
Budget for new gear would be around the £700 mark once all is sold if I go down that route, OR, stick with it.
The problem with modellers is that we can flick between a multitude of presets, carry out the same muscle activities, and get Different feedback. This is disconcerting for our brains. If it happened in driving your car your brain would shout Danger! Something wrong with car!
I remember driving an old Mini again after many years in modern cars, and really enjoying skittering round bends with the steering wheel shaking but telling me exactly what the tyres were doing. Back in my modern car that went round corners much faster with pin sharp prescision I realised how I missed that level of primitive, straight to brain feedback.
I went back to amps from my Kemper because to get what I want out of the amp I have to fight with it a bit. But my brain actually likes that as its back to learning kinesthetically.
So no, you are not losing the plot.
I've noticed this with more or less every digital modeller I've used, and the more your ear becomes tuned in to it the harder it is to leave it alone. I've just sold my Vox AD30 - which I really liked to begin with - because of it. OK that's not an expensive modeller, but it's not a bad one either.
Analogue solid state seems to be somewhere between the two.
So far the only modellers I've played which didn't seem to be like that are the Yamaha THR100 - but I didn't play that for very long - and the Blackstar ID60, but I didn't like the voicing of that very much overall, so it's possible I just instinctively stopped trying to tweak it.
In my mind the way to do it is find a good model that you like then stick to it
No matter how tempting it is to change amp and setup for every section of every song it doesn't sound natural
If you went to see a band and the guitarist had 50 different amps on stage that he switched back and forth along every song you would find it very disconcerting ... Yet with modellers this is what I see a lot of people doing
Not to mention every time you change something (like guitars) all 50 amps would sound slightly different
I pick one amp (two at most) that I like and then build my sound around that
In the Helix I use the Soldano Clean and provide all my drive using pedals
It sounds great because that's what I did in the real world so I know how it works
Just because we have all these amps available it doesn't mean we need to use them
It's like turning up all your pedals to max.. After all I've paid for that gain, I'm going to use it all
With the Helix most of my sound comes from the Thorpy gunshot I have looped in.
And most of the power amp sound comes from the pair of Fryette Powerstations that feed the Neo Creambacks
So the only thing I'm really modelling for my onstage sound is the eq of the Soldano
FOH has a couple of miced can models but to
Me that's just an improvement on the couple of redboxes I used to use instead of micing the cabs
Perfect!
I think you're on to something. It's VERY good at what it does, but it seems to just be lacking that little spark ya know?
You may be right mate!
The Amplifire has so many pluses, or tailing and ability to practice at home are perfect for what I need at the mo. I'm not sure I'd be as happy to gig live with it in the covers band, and my old originals band has just been booked for a gig in November so that may be firing up again and becoming more frequent. In that situation a full range pa isn't something that's often provided at small gigs unfortunately so I would need a 30-50w amp of som sort for that occasion, and tbh, right now I'm not in a financial position to have both :,(
A compact, loud combo may be the key.....
