ABY Box/Pedal
DanRDanR Frets: 1041
Im after one of these to make life a bit easier.
Is there much difference between them all?
I've looke at an Orange one at £119 and fender ones at £25.
Do I need to make sure it's buffered and isolated or does it honestly make no difference.
https://www.gak.co.uk/en/orange-amp-detonator-buffered-aby-switcher/128421
https://www.gak.co.uk/en/fender-aby-footswitch/100182
  • thermionicthermionic Frets: 9671
    Isolated will cure ground loops but I don't think you can predict if you'll suffer with your particular setup. And that might change in a different venue.
    Have a look at the Bright Onion isolated one, it seems very reasonably priced (not much more than the Fender, which I suspect is just jacks and switches inside that box, and a couple of resistors for the LEDs).
  • jpttaylorjpttaylor Frets: 465
    Another shout for the Bright Onion loopers. They're a bit more expensive than the Fender one, but you'll be able to reverse the phase of the second output and the ground lift in case of noise. Both features may not entirely be necessary but it's better to have the option there of using them if need be.
  • John_AJohn_A Frets: 3775
    And one more vote for Bright Onion. I have their ABY and it's been great
  • DanRDanR Frets: 1041
    I found some vouchers for Amazon so bought the Orange one.
    I shall however look into the onion one aswell.
  • gordijigordiji Frets: 786
    Radial Big Shot. .
  • +1 on the radial. Great unit.
    Probably pretty similar functionally, the Orange one's prettier, the Bright Onion one quite a lot cheaper
  • edenfield99edenfield99 Frets: 349
    edited June 2016
    Radial Big Shot....or Ry Cooder's Little Green Man which I'd like but I don't think he'd build me one - http://rycooder.nl/pages/ry_cooder_Instruments_gear_amps_effects.htm (actual his is just a Y -box but still :) )
  • DominicDominic Frets: 16152
    Radial ........best in class
  • shaunmshaunm Frets: 1633
    John_A;1130337" said:
    And one more vote for Bright Onion. I have otheir ABY and it's been great
    Plus 1
  • p90foolp90fool Frets: 31662
    That's not a realistic comparison, you're comparing onions to oranges.
